1 - 20 of 30 Posts
i need help from the body shop people. how can i pull this dent or fix it.
any help would be appreciated
thanks
silveradoboy
how did that happen that doesn't look good! and just take it to the body shop they should be able to pound that out
a dumb move on my part..... i forgot to pump the brakes after replacing them. and just put it in drive and the car didnt stop till it hit the truck tailgate. i just had a spaced out moment.
silveradoboy
silveradoboy
it happens to all of us, only human, be glad u weren't at highway speeds and that happened! but yes around 200 dollars to do at a body shop unless you look at a junkyard and try to find a cobalt thats the same colour cobalt thats been rear ended and has a good hood, and just replace it cheaper then getting the one fixed u have possibly
I would just get it repaired and repainted, as long as your car has not sit in the sun all day for several years, you should get a color match pretty easily, any body shop can make that look new again, plus, any other scratches on there will be wiped out also.
Costly brain fart. Anyway a good shop will pull that out like new for sure don't know if 200$ will cover it though.
if it's creased, most paintless places can't do it, it's going to need streightened and filled
I think it's time for a Carbon Fiber hood... :)
U 913l
Yes, not sure what the U stands for anymore. It use to stand for Urethane but urethane is not use anymore.
---------- Post added at 08:33 PM ---------- Previous post was at 08:33 PM ----------
Unless it was still used in 2007 maybe.
Here is the RPO list for the other codes on your sticker if your interested to know.
1 - 20 of 30 Posts
