Hooking Up a System
12K views 2 replies 3 participants last post by  Iceman62
#1 · (Edited by Moderator)
I recently bought a 2008 chevy cobalt Ls 2 door coupe. I love the car and really wanted to hook up a system to it. I went out and bought a new headunit, 2 ten kickers, an alpine amp and also a dual amp because i thought there was a problem with the alpine, i got the wiring harness for the headunit and the kit for the amp. My problem is i'm not getting any power to either amplifier and im not understanding why, i think its a problem with the remote because i tested both my ground and power wire. If anyone has any advice on how to wire the remote the correct way please reply. THANKS FOR READING!!
#2 ·
You can test the amp by touching the remote wire to your positive 12 volt source, the amp should turn on. The way I wired my remote was by running a wire to the fuse box on the passenger side of the console and used an atc fuse tap Cooper Bussmann/ATC fuse tap (BP-HHA-RP) | Fuse and Accessories | AutoZone.com plugged into the windshield wiper circuit so the amp turns on when the car is on.
You have insufficient privileges to reply here.
