1 - 20 of 184 Posts
Ok Lets start off wit hthe tools needed.
1)Fishing String
2)Armorall Orange clean wipes
3)white rag
4)Blow Dryer
Ok first off you have to take a 12" Fishing string and work it behind the letters. Be sure to keep it pulled up tight against the letter so you dont cuase any chaffing agains the paint. Work it back and forth to cut the letter away from the tape.
After you get al lthe letters and chevy emblem broke loose, take your fingernail and pull off as much of the tape as possible.
Then take the blow dryer and hold it against the paint for about 5 minutes to make the glue real gummy.
Take the white rag and run it against the glue pretty hard. It will cause the glue to ball up with the rag fragments.
Take the Orange clean wipes and clean it off. It take a few times of repeating the last threee steps to get it all off.
Then take a cleaner wax and wax the whole trunk to get all the minor marks you might have put in it out.
Last but not least, Use a good finishing wax and reaply to the trunk.
Total time:: 55 minutes.
Difficulty level. 3
P.S. Also works with the Small GM badges o nthe sides of the car.
I'll try to get some pics of the finished product today and post them.
Good write up man!!
Discussion Starter · #3 ·
Thanks man. Yeah you loose like 20lbs when you take off that big ass chevy badge on the trunk!! HHAHAHA I'll get some pics up later. Looks completly different and getter now.
Discussion Starter · #5 ·
Thats what I mean. Its a level threee cause I'm a noob.... I'm still gettin use to the whole modding myself thing. I always got help with my civic but since this is a new car no one in my club has any expeirience with them so its just me to do all the work.
it's cool, im just messin anyways...it was my first mod along with tint because i couldnt stand the ugly badges...i painted the bowties (front and rear) and took the rest off
55 minutes did u do the whole trunk. I got the two gm emblems and the ls off in 15 minutes. If u want something that works real well use bug and tar removal u can get it at autozone.It works real good. Getting the black tape behind them was a b**** though.
Good writeup though
Discussion Starter · #9 ·
I did the whole trunk, and the gm badges. I didnt have any good solvents to take the glue off. Thats why it took so long. I was too lazy to go to the auto parts store to get any. As I progress with the car I will write more DIY's.
The other reason it was a level 3 dificulty was because of the tools I had were not the proper ones. The blow dryer was pretty wore out.
Thanks for taking the time to do a write up.
I found that if you use the blow drier on the emblems first (before attempting to take them off), until they are hot to the touch, you can remove the emblems and their tape backing together. The bigger emblems need the fishing wire assistance though. Then some wax/buffing to remove the little bit of glue that remains.
Cool, I'll have to try do this in the summer or late spring. I want to take out that annoying car dealership thing that they stuck on the trunk....:/
Just one thing though, will the paint under the emblems and stuff be discolored?
Discussion Starter · #13 ·
Comes out very nice!! The only way you would have discoloration is if you waited and your piant was faded. The sooner you do it the better!!
? When you take off the big Chevy Emblem in the Center of the trunk...will it have holes? Or....is it just double-sided tape like the rest of it letters?
double sided tape....and i debadged my 02 Ram in 06 and it had a shadow where it said ram 1500 on the doors...a good clay bar and wax and a few car washes and it blended fine.....do it man...looks cleaner
and this is really random but thats how you take the "cobalt" lettering off of the back too?
same way, if you are careful enough, you could reuse the lettering somewhere else, i have seen it placed in other spots too
1 - 20 of 184 Posts
