1 - 17 of 17 Posts
well finally they sent me my power steering recall paper in the mail, so im gonna have my power steering back. so my question is, is there a way you can get the steering wheel off without the airbag going off? i know i could pull the fuse, but after that how could you?
disconnect the battery. wait 15 minutes. there are two little holes on the side that u stick something in and push the "rod" that's inside and that releases the airbag. Then you're still going to need a "steering wheel puller"
hawaii icon
Disconnect battery,
Pull the fuse,
Release the airbag clips by putting a small rod into the small holes on the side of you steering wheel.
There's 2 sets of wires, disconnect those.
Now the airbag is off.
In the middle you'll see the end of the steering column, it has a large nut on it, remove this.
Now your steering wheel is completely free of any fasteners. Unfortunately its such a tight fit on the shaft that it won't just pulling on it. go somewhere and pick up a steering wheel puller, attach it and slowly draw the steering wheel off the shaft.
When putting the steering wheel back make sure you line up the master spline correctly.
hawaii icon
Same here :p
yeah i put a steering wheel in my old s10, but no air bags so i just didnt know how to get this one off. thanks guys!
Did the aftermarket start making airbag steering wheels?? I know Grant was making one for the GM trucks, didnt know they made them for cars already.
i have a sparco wheel that ive been meaning to put in. one problem. i need to pass inspection to re register the car in 15 days. i have to re install the airbag, get a new gas cap and a new throttle body. consider this if you plan to go aftermarket.
Yea thats why I was asking. Also by removing the airbag, you are removing safety equipment, which can get a hefty ticket. One of my soldiers in Tennessee got a $500 fine for removing his.
hawaii icon
No prob man!
1 - 17 of 17 Posts
