1 - 14 of 14 Posts
Ok so I picked up an SS stock pillar a while back and was originally going to throw in interceptor in it, but then I decided against it as the money was better spent on school.
The other day I picked up a Glowshift tinted 7 colour vacuum gauge for like $40 (about $50 shipped). The gauge comes with everything you need to install it, but the wires on the back are short and there is no add a circuit.
Note: I would recommend disconnecting the negative terminal on the battery for added insurance, since you are working with electricity.
Basically everything you need is as follows:
-A buddy to help. preferably with skinny arms
-10mm socket
-5/16" socket or wrench
-torx bit for the pillar screw
-Mini-fuse add a circuit and a 10amp fuse (from canadian tire. came with several mini-fuses. i opted for the 10amp, but you can try less)
-A good pair of snips
-Wire strippers
-A good wire tap
-1/4" rubber fuel line hose (you can use windshield hose if you want, but since it is vacuum I thought the fuel line hose was a safer choice). Now, if you are a 2.2L, you can get like 4" or so. If you are a 2.4L (2.4 manifold), you'll need about 18"
-2 small hose clamps for the 1/4" fuel line hose if you have a 2.4L manifold, none if 2.2L
-Electrical tape
-Solder (sp?) and soldering iron
-Vice, or something or someone to hold what you're soldering
-About 5' of wire. I don't know what gauge the gauge wires are, but they're fairly small. Chances are you will have some in your house somewhere
Ok, so here we go!
Step 1
Get about 6-8" of black wire. Get about 2.5' of red wire, and another piece of red wire at about 2' (or yellow if you have it). The gauge wires need to be stripped about another 1/4", so do that. Then strip the extra wires to match. Now twist black to black, then yellow to the shorter red piece. Now take the orange and purple and the longest red piece and twist all 3 together.
Step 2
Now have your buddy/vice/mickey-moused solution hold the wires still, then solder the twisted wires together (you'll be doing this to all 3 so it doesn't matter which one you start with. Just don't burn yourself with the soldering iron. That shit gets hot.). Check YouTube for a how-to on soldering if you don't already know how (don't be discouraged though, because its really easy and the materials will cost you like maybe $10/15 at RadioShack)
Step 3
Unplug the soldering iron and put it somewhere to cool, but make sure it doesn't touch anything. Let the connections you just soldered cool, because they're probably still hot. When they're cool, take your electrical tape and tape the shit out of them for extra protection. It should look something like this:
Step 4
Now take your stock SS pillar, and your snips and cut out the plastic mounting piece for the stock boost gauge. It is in the way, so it has to go. If you have a dremel, use that because the snips are less than pretty in their results. But out of sight out of mind prevailed for me so whatever.
Step 5
Now put the gauge into the pillar, and use the supplied bracket, nuts, and washers to hold it in. I would really recommend getting in the car and trying to hold the pillar where it will be installed so you get the rotation of the gauge just the way you want it. Once you do that, tighten the two nuts on the back with a 5/16" socket or wrench and the gauge is mounted.
Note: You can also do this as step 1 if you like because the gauge being in the pillar lessens the chance of it being damaged while you're soldering everything. I actually did it that way, but you can do it however you want.
You'll end up with this when it's mounted:
Step 6
Now go in the car and remove the plastic trim piece with the trunk button in it. Just pull on the bottom in each corner and it should pop out. Be careful though because the harness for the trunk button is not long and if you pull it too hard you'll rip the trim piece and the harness off. The harness is held on with a little clip on the bottom. Use a small flat head to pry it enough to remove it. Now attach the vacuum line supplied to the back of the gauge. I got mine on like maybe 1/4", so don't bother trying to get it on like mad. Do whatever makes you feel good, but I'd say at least 1/4", like so:
Now run your wire and vacuum tube down the side, pictured here:
The vacuum line will be kind of stiff, so be easy with it. If you kink it, its pretty much done. Not forgiving at all. Just take your time and be careful. If you have a sunroof in your car you will have to fight a bit more with the pillar to get it on there, but she'll go. The brown rubber line is the drainage hose, don't damage it.
Step 7
Now I would recommend running the vacuum line into the engine bay. To do this, you will be using the rubber gromet behind the clutch pedal. Its a ***** to work with, so have fun. Get your buddy with skinny arms to reach in the engine bay, under the harnesses to the left of the ECU and above the transmission, then kind of under the brake booster. You'll feel the gromet eventually. Here is the gromet from inside the car:
Make sure you run it away from the clutch pedal. Depress it to make sure it will not be touched. Have your buddy pull the line out away from the gromet in the engine bay, but go slow to make sure the line doesn't kink. Do not bother with the wiring at this point.
Choose Your Own Abortion
Ok, so here is where this turns into a 'Choose Your Own Adventure' book, but likely more abortion-ridden. If you have a 2.4L, or if you have the 2.4L intake manifold, continue with Step 8. If you have a 2.2L with the stock 2.2L intake manifold, skip to Step 9.
Step 8
Ok, so now its time to hook up the vacuum line. This is for the 2.4L manifold. The 2.4L manifold does NOT have the little nipple near the throttle body like the 2.2L does. Instead, you have two options. Option 1 is to tap into the brake booster line, but I don't recommend that one, on the off chance something goes sideways and your brakes are compromised. Option 2 is the one I'll discuss here, which involves the removal of a vacuum line from above the throttle body. This hard plastic line goes from the intake manifold to some emissions thing. I don't remember what it is, but its the little plastic canister looking thing to the right of the valve cover. What Dan and I did here was we removed this line and the two fittings all together (just in case it needs to be swapped back), and replaced it with 1/4" fuel line hose (not fuel injector hose like I almost bought mistakenly haha). The stock plastic hose is held on with little clips on each end fitting. It just pops off easily (Don't remove the actual line from the end fittings. Remove the whole thing). You can start with either end, but be very careful because they are plastic ends that you jamming that hose onto. The one on the manifold is the more fragile one, so be careful. We only got the line on like 1/4-1/2", so don't bother trying to get it completely on, because you wont. We used little hose clamps at each end for added insurance, but its on there pretty good even without them. Be careful tightening them though as the fittings are plastic. Now, you can cut the line somewhere near the middle, or the right of the motor so you can insert the T fitting supplied with the gauge. The T fitting supplied has a little brass insert in one of the points. This is where the vacuum line attaches. The other ends go in the new line you've installed. I'll just show the picture here and you can figure out what needs to be done:
This is the fragile fitting. BE CAREFUL.
The emissions (?) thing beside the valve cover:
Step 9
If you have a 2.2L with the stock 2.2L intake manifold then this part is a lot easier. If you look to the bottom right of the throttle body, you will see a little black vacuum cap. Use a small flat head and carefully remove this cap.
Note: If you have a 2005 or 2006 then this is a lot easier because the throttle body is different, and there is no harness in the way like mine has.
The fitting is 1/4" approximately, so the 1/8" tubing supplied will not fit on it. What I did was I used some of the extra 1/4" fuel line hose used on the 2.4 install and just connected that at the intake manifold, then I cut the two smaller ridges off one of the T fitting (NOT THE ONE WITH THE BRASS INSERT) ends, and popped the vacuum cap onto that. Make sure it fits nice and snug. Then I put the other end of the T fitting into the rubber line (again, not the end with the brass fitting). Here the end result. You can use less black hose if you want, but I figured it didn't really make a difference,
Step 10
The clear tubing does fit on the T fitting, but it takes some effort. Just gradually work it on and you should be able to get it to the second ridge. Maybe more, but I gave up because my hands were killing me. At this point we started the car to ensure the gauge worked (the vacuum gauge portion, not the lights and what not) because its a mechanical gauge, so it will work no matter the power status. If all is well then move on. At idle I think its around -22psi or so.
Step 11
Now you can start wiring. The yellow wire off the gauge is the constant power wire. I have confirmed that the gauge draws 40mA, which is negligible at best, so it should not brick your battery. I tapped into the power wire going to the cigarette lighter under the HVAC controls. For this I used a wire tap. Don't close it up completely until the gauge is tested later. Here is it pictured before closing the completely:
All the trim easily comes off, so just search around if you don't know how to remove it all. Everything clips and snaps together like a cheap ass set of LEGO knock-offs.
Step 12
Now its time to run your switched wire. I strongly recommend using an add a circuit thing because you don't harm the factory wiring. You will likely have to crimp the switched wire from the gauge, into the add a circuit. You'll see in a minute if you don't get that explanation. I used the 10amp wiper fuse (fuse #15 IIRC, but double check on the back of the fuse block cover). I also chose to use a 10amp fuse for the gauge, so in the end the add a fuse has 2 10amp fused in it. Here it is:
At this point, I had Dan ground the gauge so I don't know where he grounded it, but you can use any GOOD ground source. Now double check all your connections, then put the car to run, but don't start it. At this point the gauge should light up brightly, and you should be able to switch the colour with the button on the gauge. Also check to make sure your wipers are still working. Turn the car to off, then back to run (again don't start it), and make sure the colour is the same as when it was last on. Now you can begin cleanup and reassembly of everything.
Here is the gauge off, when I finished:
Here is is while waiting for a light, at night:
Even if you aren't installing this gauge specifically, some of the steps should be universal for other gauges.
If you like this how to, please comment and say so. It took a while to write.
Cheers,
Kieran
DISCLAIMER: I am not responsible for any damage you may cause by following this how to, or any warranties this how to may void. This is a DO AT YOUR OWN RISK modification.
Update: So apparently that isn't a constant power from the cigarette lighter. I'll have to do some searching for a proper constant, or I'll just change it every time like how I turn my fogs on every time. When I find a suitable constant I'll update this thread.
i gonna have use this when i get my gauges good work!!!!!
Yeah I would have preferred to find that little fitting like what you have, but I couldn't find it anywhere so this will do for now.
Thank you for posting this. I was thinking about getting one for my balt. I think it would be awesome when used in conjunction with the INST MPG display.
Yep, this is basically how all those eco meters work...it's just a vac gauge.
Ok, update.
With the cigarette lighter as the constant, it wont remember the colour if I drive around then shut the car off and lock it. It defaults to blue everytime I start it.
However, if I put the car to run without starting it, change the colour, then shut it off and leave it for a while (overnight) it remembers that colour when I start it in the morning. IDK wtf is wrong with it now lol. Someone suggested I tap into the door lock fuse for it. I MAY try that if I get bored one day, but I don't want to spend another $15 for an add a circuit lol
Wire to a different constant...or try another one at least.
Yeah I don't have time to do it now so I'll just make do, but when I get a chance I'll try and find a better one. Its weird though because I have an iPod charger always plugged into the other ciggy lighter and its always on. Stupid car lol.
Also, I've noticed that with this gauge and sunglasses on during the day it is hard to read. Without sunglasses its ok. It came with a little visor so I think I may mount that when I get a change and see if it helps at all.
Yeah, looking at it, I could imagine it would be slightly hard to see.
Discussion Starter #12
Update: So apparently it remembers the green colour fine for some reason. I don't really care that much though since it matches the stock cluster the most. Its been working fine, and it hasn't been overly gentle weather so thats a plus. Its been like super mega cold here a few times, and its been fine. I've noticed that the needle can be a bit jumpy at times when its moving but overall its smooth and ok.
As for the gauge itself, well. Shipped to me it was like $50 so I can't really complain there, but I'm honestly not that impressed. The colour changing would be nice if it could remember all the colours, but since it only remembers the default blue or green its a let down. The constant is fine, otherwise it wouldn't remember the green. At night the gauge is easy to read and the colour is bright enough to be easily readable, but not too bright to blind. During the day though its balls. Like I'm lucky if I can make out the numbers on the far left. Right side is a joke. I do have a sunroof, but given the location of the pillar it isn't affected by the roof being open or closed (with sunshade). I would recommend a white-faced version of this gauge instead. It would also be nice to be able to have a harness on the back of the gauge for easy removal too.
I'd give the gauge a 6/10.
I have noticed my fuel economy getting better though, but that may be because I switched to the INST MPG DIC readout. Easier to know when I need to let off. The gauge helps a bit too though, but more with throttle control than anything.
If you're wearing polarized sunglasses it can actually block you from seeing things like the mileage display, watch face, or other things that are covered by something clear if you are at a certain angle - it has to with the way the polarization is put into the glasses it's like a cheese cloth mesh if you look at it under a microscope and it's the same if were look at tempered glass with polarized specs on it looks like the glass has streaks but its just some light is getting through and some isn't - I was an optician at one time - sorry for the long explanation
1 - 14 of 14 Posts
