Here's the install as promised. Pictures are numbered in lower righthand corner.
1 Arm rest from donor car (2007 Cobalt LT Cashmere Metalic).
2 Arm rest mounting bracket before cleaning.
3 Arm rest mounting bracket after cleaning and paint.
4 Removal of rear cup holder. This just snaps out.
5 Removal of park brake trim. This just snaps out.
6 Insert mounting bracket through opening. As you can see hole is too small so unscrew back of console (Two 7mm screws) so you can spread it a little bit.
7 Drop mounting bracket in position and screw the four 10 mm screws at each corner.
8 Insert Arm rest and slide into slots at front, screw two 10mm screws at back of bracket securely.
9 Insert shorter cup holder into place.
10 Re-install parking brake trim and Voilà.
Probably a 20 minutes job if you don't take pictures. Hope this helps somebody.
Easier to access the front bolts of the base bracket without parking brake trim though.
wow I dunno what I was thinking, but yes youre totally right about the trim piece. For some reason I read to remove the parking brake and thought you meant the whole handle part. :blink:
