1 - 16 of 16 Posts
Ok I already installed mines but since I havent seen anyone who did this Why not give it a shot. I have to come back and redue some things but this is just a ruff draft anyway.
Ok things youll need
Wire (I believe 12 guage roll from your auto store)
New halos projector lights (Duh)
Adapter fuse (from your auto store)
12 Guage crimp wire connectors and ring connectors
crimping tool
an extra 15 amp fuse for the adapter fuze
and a good sunny day LOL
ok first your projectors (Duh) depending on which kind you have mines where the sonor ones with the projector already installed.
Next remove your old lights from the car and take out the wire connection and lights from the housing, These are the lights and housing from my projectors since mines are already in i marked the lights and connectors you have to take off the OEM lights to connect to your projectors
as seen in the picture its easy to get out just MAKE SURE YOU DONT TOUCH THE BULBS.
Ok now that thats takin off just reinstall then in the projector lights same way you took them off. youll notice that the connection to it just connects easy so connect em
and wallla your lights are connected.
now to connect your Halos and L.E.D.s
what I did was just connect all the blk wires together and the red and white ones together so they can show at the same time,
use the crimping connection pieces and connect all the blk in one connection and all the red/white in another connection.
Ok once there connected ground the blk to the frame on both sides
I used the closes place to ground it and this part looked great when you unscrew it it shows metal contact use the ring connectors on the ends and just tightin them down
Ok now for the positive. take off the top to your fuze box and look for the park light fuze
this is the fuze youll be using
now attach the extra 15 amp fuze to it and take the fuze out the fuze box and add it to the adapter.
What you wanna do is run a wire from the ends of the positives to the adapter, only two wire will be goin in the end of it so it should be hard to fit it in and crimp it together. Once done just place in the fuze box
once thats connected test and it should work when you turn on your park lights. they wont flash when the turn signal comes on they just stay on and when you turn them off they turn off also. when its night time and the auto lights come on they come on by them selves also.
once youve checked them out reinstall the lights
and wait till night time
and now your projector and L.E.D.s halos are connected.
Enjoy
Awsome job shanks, good write up, this will definatly come in handy to alot of people. And they look great!
could we do this halo w/ projectors kit and then do an HID kit too? anyone done that? i'm not doing HID w/o projectors.
yeah almost everyone on here and css.net with projectors have hid's
i have 8000 and am glad i got them.
you cant see anything with the stock bulbs that come with these projectors at night therefore hids will be a good investment with these lights.
Good wright up. There is no reason to run a wire all the way up to the fuse box though.. Simply use a test light to find the wire in the headlight harness that has power when you want them on.
Thats what I did. Ran the three LEDs to the runing lights and the halos to the fog lights. Turned out really nice I like the options as far as what lights to run with.
wow this is a a great instruction. im new to the bolt and i think this would be a great mod cause im tryin to keep them simple but look good. so ill give this a shot. any particular place you guys buy from or just are all Halos the same?
1 - 16 of 16 Posts
