1 - 9 of 9 Posts
How-To: Install HID H11 Kit For Foglights
H11 12,000k kit Bought From BUYHIDS.COM HID Lights HID Kits Xenon Headlights Kit HID Headlight Kits HID Conversion Light
Tools Required:
10mm Socket
Socket Wrench
3/4 Extension
Step 1: Remove the 4 top bolts that hold the headlights and bracket in place & the 3 Push clips on the grill.
Step 2: Pull headlight out from the outside as shown. Takes some wiggling but it will come out
Step 3: Remove the 2 lower bolts that hold the bracket in place.
Step 4: Remove the headlight bracket by wiggling it out.
Step 5: Unplug the horn by squeezing the plug. Push wire to the side. This makes it easier to install the bulb and less chance of it hitting or catching on something.
Step 6: Mount your ballast. I already have a headlight kit so i mounted it on the inside of the bumper with some 3M Double sided tape. Make sure to clean the area before hand. For people in the colder states use a hair dryer to heat up the area before hand so the tape sticks. Ive had mine mounted for 1+ Years without issue and its still mounted.
Step 7: Wiring up your HID Kit. Its completely plug-n-play. Follow the picture before for where the plugs go. When plugging into the ballast. Clips on the plug go over the smaller bump on the ballast. If it does not work reverse it. When installing the bulb, **Be VERY CAREFUL** not to hit the bulb on the foglight and be very gentle when aligning it up before twisting it into the slots.
Finshed Product: 12,000k Bulbs
no - its not same for the HIDs - i dont get the long wire that conects both balast and conects to the post and the fender bolt so I think HID instalation is different from the BI-Xenos
I got HID 9007 hi/Low - 8000k and I got same kit as the fog light kit in theis how to exept my bulb is different
I guss it should be same as this how to for the headlights as well - I will try it and see if it works the same way and will post the result
Follow the foglight kit, its 100% Plug-n-play. you just connect an extra wire.
I have the HID Xenon Headlight Hi/Low kit and am having trouble installing it. The issue is the blue plug will not fit through the black retaining ring to plug into the stock blue plug. Are we doing something totally wrong? Has anyone else installed the same set up?
A picture i got from chip shows you put the wires through before the connector. Remove the wires and flip the connector around and push it through first. Ive sold 100+ of these kits and none have this issue. All the blue connectors are the same size.
1 - 9 of 9 Posts
