1 - 20 of 208 Posts
i know there's a few people on here that have been requesting a how to for painting headlights. well, my passenger side light from ebay has arrived so i figured i could help everyone out. i did the driver side a few days ago and it turned out great!! try to bear with me though, this is only my second ever how-to so if you have any questions just ask.
first thing you obviously want to do is remove the headlight from the car. i have no pictures of this since i am using a back-up set. ok so tools for the job, a flat-head screwdriver, needle-nosed pliers, oven/hairdryer, a tool to remove hex screws, painters tape, and patience.
the second thing you want to do after poking your cars eye out is to remove all the bulbs and wires.
the big black ring around the headlight bulb can be a PITA to turn, with a little muscle just turn it counter clockwise and it'll pop right out.
now there are two ways to heat up the sealant in order to pull the lens off. the first method is a hairdryer which will have to be aimed into the high/low beam hole. this seems like it may be an easy, quick way to do it but it isn't. trust me, i tried. so i went with option two, the oven. i chose the oven method because it's easier to heat the sealant evenly plus it's a lot faster. i pre-heated the oven to 200 degrees and baked for about 10-15 minutes...
aluminum foil is optional. i used it simply because i didn't know if the sealant would make a mess, it didn't.
unfortunately i got so into my project that i forgot to take a picture while removing the lens. what i did was when the sealant was soft enough i took the flat head screwdriver and worked my way around the lens until i could pull it off [start at the corners] the sealant can be a bit stringy so try not to get it all over the place. i've read that some people will scrape the sealant off but then there's others who say save it and reuse it, which is what i did.
now you'll have to remove the three hex screws to release the chrome piece.
after everything has been pulled apart, you will be left with this...
the piece i circled in red, do not touch!! **note** the orange reflector and signal cover just pop out.
the next step is to tape off the areas you do not want to paint. i also chose to scuff up the "chrome" with 1000 grit sandpaper and add a touch of primer to help the paint stick better.
next step, paint...
my choice of paint, three coats of krylon fusion satin black. i used it on my interior and also my bowties and all is holding up well!!
after you're satisfied with your new paint job and all is dry, remove the tape
here is a tip for putting the signal light cover back on [if you choose] doing so will prevent the paint from getting scratched by the covers tabs when you slide them into place...
and finally, put it all back together. i put the chrome piece back into place and then put the lens into position and tossed it back in the oven for another 10 minutes or so. just long enough to soften up the sealant. when i took it out i worked my way around the lens pushing that and the clips back into place. after that i took a tube of clear sealant that i picked up at autozone and added a second layer of sealant around the edge for extra protection against leaking. this is opintional of course but it also wouldn't hurt.
and finally, the finished product..
well there you have it, fresh painted headlights. hope this helps! any questions just ask.
Great DIY!
When I did mine I baked each coat of paint in the oven at 200 for about 10 minutes. That seemed to help the paint cure but also made the house smell a little.
To add to the right up so everyone gets the best results possible I thought I would throw in my 2 cents. After the assembly is taken apart scuff the surfaces to be painted with 800 grit sand paper. Prior to primer being applied wipe down the surface with some paint thinner or Preps All (pick it up at WalMart) on a paper towel so the surface is clean. Try to avoid doing this with a cotton towel so the dust bunnies don't jump onto the surface. What ever you are painting do not set it on the ground or have a hard surface underneath it. No matter how clean you think you are being the pressure from the can can blow dust into your headlight, now you are stuck with the decision of breaking it down or trying to massage it out and apply another coat. Now apply the primer, if all is smooth move on, if not massage it with some 1500 grit sand paper and respray that area. After the primer has had a chance to harder prep the surface again with the paint thinner allow to dry then apply you paint.
I added this to the orginal post for this before the forum got wiped. Good DIY, like I said, just my two cents.
A quick note the tool to remove the hex screws is a t-15 torx bit.
Thanks for the post you saved me from spending $150 on Ebay!
i wanna do that but looks hard
well not hard but riskey and how do you put the lens back its sticks or what
Do you think it would be a bad idea to use a heat gun instead of a hairdryer pointed in to the hi/li beam hole? I used it for debadging, and it nearly melted the 30 lb. Chevy emblem. it's a 750º and 1000º heat gun.
I was thinking about doing this but instead of going black I was thinking about painting them my factory exterior color. How do you guys think that would turn out? O by the way my Balt is the darker red one. Maroon I guess...lol
i think that would look great. i saw a yellow z06 corvette that had his headlights painted yellow. and it looked real good, i dont see why red wouldnt look good. i say go for it!
But I wouldn't just go over the silver, it may not match, might kinda look like red silver (if that makes sense) I'd put a primer on first.
Oh yea I would primer it first. Maybe I will start working on it next week!
How do I get the headlight out? I removed the two bolts and tried to wiggle it out but it didn't seem like it would come out.
You remove those two bolts, then you kind of pull out on the outer edge while pushing in on the the other side of the light. just kinda screw around with it. its tricky but they come out fairly easy once you manoeuver it right.
Done this a few times myself replacing bulbs. It will help IMMENSLY if you remove the upper corner plug from the grill where it meets the headlight. Its kinda like a plastic plug and the center of it has this little thingy you pull up on to get it out. Not a technical explanation I know, but if you see it you'll know what I mean. Once you get it out, it will give you some extra room to play with in getting the headlight out.
Thanks guys. It's done!
1 - 20 of 208 Posts
