1 - 16 of 16 Posts
I have a 06 lsj and I cracked my trans on the bottom and drained all the fluid also fluid up on top. Question is how do I stop thag from happening again. I have a solid motor mount and rotated front and rear trans mounts and stock upper trans mount.
So you have solid rotated transmission mounts?
Build a skid plate or be more careful.
Levee
How it broke and where it broke can help diagnose the issue here.
I got on it a little in first and it cracked. Not from impact or anythink. I thoight a axle broke I'll see if I can add a picture.
---------- Post added at 08:20 AM ---------- Previous post was at 08:19 AM ----------
I cant photo bucket is messing up. But it's on the very bottom just almost where it connects to the motor.
Was there lots of wheel hop?
Levee
How tight were the bell housing bolts?
What's your power, grinding gears? Looks to me like a tooth broke off and got wedged in there where something had to give.
Anythings possible, just something being cast wrong. It's the only way I can imagine that breaking open though.
has to be internal failure flywheel tooth broke off or something
I had the tooth ring come loose on an old gm car I had years ago busted the whole bottom out of the trans.
1 - 16 of 16 Posts
