1 - 11 of 11 Posts
5 LUG JL9 Axle Only
Assuming that you have your disc brake rear axle prepped to swap out the axle is pretty simple.
Once you have the car up in the air and have the wheels removed etc, you will want to disengage the emergency brake lines.
The connectors are located underneath the rear cup holders, disengage the cables from the metal bracket from the EM Brake
assembly
Remove the cables slowly out of the tube
Once the emergency brake is removed from inside the car you will then want to remove the drum cover to allow the drum to cool
down so you can work around the brakes. You do not need to disengage the em cable from the drum brakes as you are replacing
the EM cables when you replace the rear axle.
You will then want to disengage the ABS, the connector is located in the center of the axle up near the evaporator. Just
disconnect the cable as it will also go with the axle and be replaced with the ABS cable on the new axle (if you dont have abs
dont worry about this step)
Once the brake cables are removed you will want to then pull the shocks off, it should be 2 bolts.
Once the shock is removed you will want to have either 2 people or a transmission stand or something underneath the axle for
when you release it from the car. Remove the 3 bolts from each bracket and drop the axle with the backets.
Replace with the new axle and attach with the 3 bolts on each bracket. The axle with the backets will hang there and you can
then work on the brakes and everything else.
At this point I would suggest attaching the brake lines, Then the regular or steel braided lines will hook right up
You will find that you will need to refab the steel sections of the brake lines to fit the new axle unless they came with it.
you may need to round out the brakeline bracket on the axle for the steelbraided brake lines to fit if you are using those
Once you have the brake lines in place and the calipers and rotors are on, its time to re attach the em brake cables. Feed the
lines through the tubes to hook up to the em brake assembly and then hook the cable into the clip on the axle and then around
on to the new calipers on the rotors.
Hook the ABS connector back up under the body at this point.
Once this is done, if you are using your old shocks and springs then you will need to compress the springs and re-attach the
shocks as you took them off, sit the springs into the cradle then lower the car on to the springs and it should sit right in.
Put the wheels back on and away you go!
Im sure its pretty obvious by the pictures but I put it in there anyways. And Honestly I dont see why doing an axle swap wouldnt work for the 4 lug either..
trust me there are a lot of noobs around here that wouldn't notice. and yes you can swap in that axle with a 4 lug but you'd also have to convert the fronts or you're gonna have a 4 and 5 lug combo. that would be totally retarded.
good write up though.
I actually meant a 4 lug drum to disc...Unless they never made a 4 lug rear disc
I know this has been up here a while and I thought I would answer this question. It wasnt just an axle swap. I went from 2 wheel disc to 4 wheel disc. I upgraded to the SS Calipers, rotors & Pads, I also upgraded the brake lines to steel. I had t Fab new lines that went between the flex lines.
However the ABS hooked right up no issues.
1 - 11 of 11 Posts
