1 - 9 of 9 Posts
Long story short, i need to uninstall my xm radio.
had it professionally put in, now i want it out due to lack of use.
The same place that installed it, is wanting $50 to take it back out. Shoooot.
You know dang well i dont want to pay to have it uninstalled.
runs from the front, to my antenna.
Anyone know how to do this?
just don't use it like i don't use mine it came with mine then the trial ran out and i was like w/e i dont really listen to the radio anyway
thing is, its attached to my antenna.
i took off the lcd [that was positioned on my left middle air vent] and stuck the wire back under the dash.
and if i want to get a shorty antenna, what shall i do?
it would be nice to have the wiring all out...i guess, just follow the wiring?
I don't really know much about XM, but Can you physically see from the outside f the car that it is attacked to your antenna? If not then you have no issues. You can still replace the antenna
Yes you can physically see the little knob around the bottom of the antenna.
Ill take a picture and post it in a bit.
here it is:
Wow! that's weak! Can't you just pry it off the antenna, and hide it behind the trunk carpet?
exactly what i just did. :)
So i understand u can just gank a shorty antenna from a car?
Is that what ive been reading? Like a focus or honda element?
Well its not as easy as just getting it off another car.. I got my honda element antenna from a honga dealership. The problem with it though, is that our base has a male tip and the element antenna is a male antenna. So they wouldn't work together. I basically had to give the antenna a sex change lol. I cut off the tip, then drilled and tapped it to the correct size. But as I'm sure you saw in the other thread, It looks like it came like that stock!
1 - 9 of 9 Posts
