1 - 8 of 8 Posts
This is a how to on how to wrap things in fabric specificly a visor in this case
What you need:
Fabric
Scissors
utility blade
flat head screw driver
fingers
patience
adhesive: I use spray adhesive from loctite that has on the can "heavy duty" read the back of the cans it will say "do not use on headliners".... dont use those ones lol.
hot glue
Hair dryer
First start by using your utility blade and cutting at the seem of your visor and letting it open itself up:
Second is to remove all the innards such as the mounting brackets and what not. The mirror you just kinda have to muscle it is plastic welded on the inside or you can cut the little spot welds. I painted all of my parts in white.
Then start peeling the existing fabric off and make sure to scrape any really big clumps of glue. In the zoomed in area there is a lot of adhesive.
Next size your fabric to your visor. I just lay it flat and cut around it roughly, like a finger tip or to your first knuckle, I suppose you could use chalk or something as long as you do it on the back side.
Next Lather the spray adhesive on thick, covering all your areas of the cardboard. the edges is where it sucks because your fabric will wanna pull up on the edges or corners particularly.
use your hair dryer and heat up the first side you want to put on fabric, with this brand of adhesive you should see it bubble and get very stringy, use your finger or flat head screw driver to touch it and make sure its not wet, not dry but an inbetweeb like a cob web. then lay it on your fabric, repeat the same for the other side, get all the bubbles off try not to peel it as much as possible because youll make the adhesive less sticky thus fabric falling down.
Next comes the wrapping You want about a finger tip of cloth around so you can wrap the fabric to the back side. Cut stress relief points around the edges of the fabric, this eliminates wrinkles, cut the relief points so there is at least the thickness of the carboard left so you dont see cuts on your edges.
to get the wrapped part to stick you can use either super glue or hot glue but i just sprayed a crap load of adhesive onto a piece of cardboard and then mixed it until it became gooy then slabbed it on like tiling kind of. did this procedure all around. at the corners make 2 directing towards the corner.
You will have to cut the holes that are covered here in order to wrap them obviously
---------- Post added at 10:06 PM ---------- Previous post was at 10:04 PM ----------
its way easier than you think and than it looks, when you get done wrapping it all, then insert your pieces and hot glue them in place and then hot glue around the edges maybe add some piping or something and squish together with the hot glue and it should all be gravy.
i did this in my car with purple fabric and black paint. looks sick. now i just need to find time to do the headliner... :eek:h:
Nice write up!
I might look into this when I have a free weekend :)
1 - 8 of 8 Posts
