Hello,
I recently purchased the shop manual for my 2008 cobalt I am attempting to replace my air inlet valve actuator. The very fist instruction says to "Remove the fuse labelled HVAC CTRL (BATT)." I have located my fuse box behind the trim panel on the passenger side. The diagram on the inside of that panel looks like the one in the image below. There are labels for the HVAC/PK3+ (10A), HVAC/IP IGN (10A), and HVAC - labels 10, 16, and 30 respectively - but there is no label specifically for the "HVAC CTRL (BATT)". Is this fuse located elsewhere or is it synonymous with one of the 3 aforementioned fuses? your help is greatly appreciated.
Pull both 10 and 16. I believe (batt) means you should also disconnect battery. 30 is the fan relay
