Car cranks no fire, everything says it needs a new ignition control module. Where is it located, i have taken the entire car apart, traced the entire ignition wiring harness and everything attached to it, and I haven't been able to find it anywhere, ...help
Ignition module is part of the ECM starting in 07. More than likely you lost the crank position sensor signal and the ECM doesn't know when to fire or fires at wrong time. Do you have a check engine light on?
That's always the best place to start, the Check Engine Light.
