1 - 9 of 9 Posts
While torquing them down after checking out the spark plugs, one of the bolts for my ignition pack snapped. I was using the proper in-lbs in torque, but it still popped while down in the hole. For something that far down, can I drill it out or use some sort of easy out? Is the car drivable for the time being?
You probably don't need that fourth bolt.
---------- Post added at 06:01 PM ---------- Previous post was at 06:00 PM ----------
Somebody must have over torqued that sucker at one point.
---------- Post added at 06:04 PM ---------- Previous post was at 06:01 PM ----------
Remove the coilpack and check how much of the bolt still sticks out. If you have enough to grab it with vicegrips pull it out that way. If not weld a nut to it then undo the bolt.
Magnet?
Woot! Good job!
1 - 9 of 9 Posts
