Hello. I have a 2008 Chevy Cobalt LT. I am having excessive inside wear of my front passenger tire. This is the only tire with this problem. There is also a noise when driving from that area. Other forums say wheel bearing but I have needed a wheel hub on another tire before and it doesn't sound nearly as bad as that did. Is it an alignment issue or could it be something else?
Levee
noise could be a bearing, depends on the noise. As far as the tire, that's an alignment issue. Probably the toe is too far positive than it needs to be. Does the tread have feathering? If your rubbing the tire on the treads side to side (basically it is smoother rubbing the tire one way as opposed to the other way)?
Welcome by the way!
