1 - 20 of 76 Posts
If you already have fogs it is just plug and play and affix the ballast somewhere with either ties, double sided tape or rivets or screws.
Well then you have 2 ways to go. OEM look or aftermarket. I'm going with OEM with my 2010.
That horse has been beaten to death already. Search for fog light.
Let me know if you can't find the necessary info and I will try to bring it back to the surface.
I don't have a bumper with the fog inserts so I'd have to find a different mounting spot. I'd like to be able to turn the lights on and off by a toggle switch. I'm just not sure how to wire this all together. In my mind I'm thinking a power source under the dash will be wired to the switch, then a wire from the switch to the positive terminal on the light, then a ground wire from the light to a grounding point.
---------- Post added at 08:43 PM ---------- Previous post was at 08:42 PM ----------
Not sure if that would work if I wanted to do HIDs
Oooooh ok lol so your going for the electrical exposed in the rain look hmm sweet can't wait to see this one make sure you make a how to on your progress.
---------- Post added at 11:01 PM ---------- Previous post was at 10:53 PM ----------
Unless you plan on mounting behind the bumper but i don't see a reason in having them then.
1 - 20 of 76 Posts
