1 - 17 of 17 Posts
ok my interior lights are on my rearview mirror and i took of the caps to get to the lightbubls but i cant seem to pull them out, anyone have any advice, i dont want to use plyers because i dont want to break the light bulb
I dont have the owners manual or repair manual here, have you tried pushing in and turning them, that may work. Other than that I dont know.
Take a pair of curved tongs and go behind the bulbs, they will shoot right out.
thanks for the advice they came out, but now i ran into another problem. i put the blue ones in and they look good. but when the car is off and locked the lights turn off but if you look at them very close, they are still on
yahh mine dome light does that too
i dont know what causes it. did you sway with LED's?
If they are LED's, sometimes they take a while to finally go out. At least the LED bulbs in my house do.
yea i went with LED but i dont have a dome light. my lights are in my reirview mirror. how long would you say it takes for the lights to turn off 100%?
don't worry about your lights turning off. LEDs drain much less power, and likewise need less power to stay lit. if you really want them off, unplug your battery. don't worry about it draining the battery - i've left my interior LED strips on all night many times, never had a problem.
i took them off ill try tomorrow, if they dont turn off after im done my first period class im putting the stock ones back in :(
the only thing i dont like about them not turning off all the way is that when the domelight is set to the setting to where the door opens the light turns on. when im driving around it is still lit dimly
Did the same with the LED's on the bike many times, and bike started up next morning fine.
Oh, ok. so they never die down and go off at all either, then there is something wrong someplace.
Discussion Starter #17 (Edited)
ok i took them out and tried them the otherway and they die down the lights are lit but no glow. even when i tunen the car off and lock it i went to work and when i finsihed they were still on. the lights dont turn off im guessing. btw does anyone know why they dont turn off 100%?
1 - 17 of 17 Posts
