I had my motor worked on and now my stereo won't work and my fob won't either, not sure what could have happened.
I have a2008 cobalt lt coupei had the head gasket changed along with some sensorsBattery in the key fob died? Hard to kill the radio working on the engine. What work did you have performed on the engine? And what year and model do you have? Miles?
They could have done a whoopsie and accidentally rehooked your battery cables up wrong when they put the car back together and fried the radio or blown out the fuse. And being a mechanic with many other cars they're working on, they May have neglected to say anything to you about it when they finished with your car. I'd suggest that you have the fuse to the radio checked. If that is not it, then you may need a new radio altogether..I replaced the battery in fob. Also
I don't know what causes the stereo to lock but I've read that they do lock. I found these steps, but (disclaimer alert), I don't know if it'll work or not. Good Luck!I had my motor worked on and now my stereo won't work and my fob won't either, not sure what could have happened.
