1 - 20 of 49 Posts
Ok so I saw this DIY here but I cant ask anything because the thread is close LOL
Can anyone explain a lil bit more in english this [email protected] :smile1:
You will need a relay for this. A 5 pin 30/40 amp relay will work just fine. Here is the wiring.
Pin 86-ground
Pin 85-High beam turn on
Pin 30-out put Low beams
Pin 87-Constant 12 volt source
Pin 87a-input low beams
Just a lil briefe and I will do this today :nuts:
Please and Thank you.
You mean you want your low beam to stay on when you apply high beam. This can be done the way that is mentioned but you do realize that both filaments in the Cobalts case are in the same bulb not sure your bulb can handle the extra heat for very long. This is more a mod for cars with seperate bulb like the G6 for instance or Malibu.
Aftermarket headlamps have the seperate bulbs. I've been meaning to do this, just never got around to it.
Yes that's what I meant, And not problem with the bulb I believe, I have dual halo projectors in my car So low beams is one bulb (8K HID) and high beam is a separate bulb (10k HID) ...Do I explain myself?
Well that's easy then, ground one side of the relay apply the High beam voltage to the positive side of the coil of the 12V relay.This will actuate the relay then wire B+ to one side of relay contact and the other relay contact to the positive on side of the low beam,
All right ...That's not english for me Sir. LOL Let me eat something and re-read to see if I understand :laugh:
I will draw you a diagram.
---------- Post added at 03:26 PM ---------- Previous post was at 03:25 PM ----------
Even easier would be to just diode the high beam to low beam.
This would be the best you would be using all existing relays and fuses.
---------- Post added at 03:38 PM ---------- Previous post was at 03:36 PM ----------
[/COLOR]You need a diode because you don't want your high beams to come on when low beams are selected.
---------- Post added at 03:55 PM ---------- Previous post was at 03:38 PM ----------
Or the old way, relay method .....
Just add a diode like a "1N4007" between pin "A2"(-) and pin "C2" (+)of connector "C2" of the underhood fuse block. It is a lot simpler than you think, just make sure you disconnect the battery before doing any electrical work on your car. Picture here shows location of "C2" but not pin out.
Um. Someone want to come do this to my car? I dont get electrical!!
Here is C2 pin out.
And this is applicable to all years, 05-10 correct?
This is a 1N4007. The silver ring designates the negative side, so wire this end to pin "A2" of connector "C2" and other side to "C2"
---------- Post added at 05:33 PM ---------- Previous post was at 05:30 PM ----------
Disconnect battery terminal. Then under the hood unscrew the boost post and unclip fuse block from it's bracket. Connectors are under the fuse block.
---------- Post added at 05:36 PM ---------- Previous post was at 05:33 PM ----------
The five screws you see on top secure the connectors in place. Unscrew the necessary one to accomplish your task.
This screw secures C2
---------- Post added at 05:49 PM ---------- Previous post was at 05:41 PM ----------
Install diode here...
According to your diagram I would think that the blue fuse at the bottom is A2. Why is the screw securing C2? Or do you have to pull off that cover to get at it?
1 - 20 of 49 Posts
