So i ordered LED lights for my license plate and trunk lights and i replaced the bulb and it doesn't work so then i swapped back in the regular bulb and it didn't work still even though the bulb is perfectly fine. so i tested the voltage and got nothing so i am thinking it is the connector possibly? I am going to stop at advanced auto tonight see if i can fix it, i took the light housing out and can see a connector and was wondering if anyone else had this problem before?
i was replacing the bulb with an LED replacement but then realized it hadnt been working for awhile but i just looked and there is a connector right behind the left hand top corner of the license plate and it was unhooked so i have to take the bumper off and hook it back up because the socket works fine cuz i hooked it up to a 12 volt battery and it worked perfectly
I second the fuse or connector issue. Take a volt meter to the wires themselves, while your headlights are one and see if you get any voltage on the wires. That would rule out a lot.
the license plate bulb is in line with the parking lights so the fuse isnt blown and i used a voltage tester and snipped the bulb socket off and put it to a 12volt battery the socket works fine but i found there is a blue connector behind the top left of the license plate and it was unconnected
---------- Post added at 11:58 AM ---------- Previous post was at 10:06 AM ----------
light bulb is fixed the pigtail connector inside of the bumper cover was unplugged so all i had to do was take the 4 pins out by the trunk to see inside the bumper and plugged them back together and used some electrical tape to prevent that from happening again...
Moderators Can close this thread thank you!
