I'm starting this thread to try and put and order in the how to's. It will be a work in progress so please be patient with me. I will be editing on my spare time. Any help or pointers can be PMed or dropped in the Crap thread. This kinda the way I want to go.
1. How To: Fabricate Your Own Air-Intake...........................http://www.yourcobalt.com/forums/in...y-want-make-there-own-intake-should-help.html
2. How To: Install aftermarket cruise control........................http://www.yourcobalt.com/forums/in...-how-install-aftermarket-cruise-controll.html
3. How To: Install LED Tail With Resistor..............................http://www.yourcobalt.com/forums/in...install-led-taillights-w-resistors-coupe.html
4. How To: Install Power Door Locks...................................http://www.yourcobalt.com/forums/install-guides-diy/30538-how-install-power-locks.html
5. How To: Install Short Shifter..........................................http://www.yourcobalt.com/forums/in...evrolet-cobalt-short-shifter-install-diy.html
6. How To: Install USB charging ports.................................http://www.yourcobalt.com/forums/install-guides-diy/30622-how-add-usb-ports-your-car-diy.html
7. How To: Paint Interior Trim Panels....................................http://www.yourcobalt.com/forums/install-guides-diy/11419-how-paint-trim-interior-panels.html
8. How To: Post pictures..................................................http://www.yourcobalt.com/forums/new-member-introductions/8918-diy-how-post-pics.html
9. How To: Properly repair a key FOB................................... [http://www.yourcobalt.com/forums/electrical/31124-key-fob-re-programing.html
10. How To: Read your tires..............................................http://www.yourcobalt.com/forums/suspension-wheels-brakes-tires/21490-how-read-your-tires.html
11. How To: Remove Headliner...........................................http://www.yourcobalt.com/forums/install-guides-diy/31701-how-remove-headliner.html
12. How To: Remove Your Interior Trim.................................http://www.yourcobalt.com/forums/install-guides-diy/11023-how-remove-your-interior-trim-mod.html
13. How To: Replace Automatic Gear Shifter Assembly.............http://www.yourcobalt.com/forums/install-guides-diy/29031-how-replace-gear-shift-assembly.html
14. How To: Replace front wheel bearing assembly hub............http://www.yourcobalt.com/forums/install-guides-diy/31449-how-replace-front-wheel-bearings.html
15. How To: Replace HVAC blower motor................................http://www.yourcobalt.com/forums/install-guides-diy/31060-how-replace-hvac-blower-motor.html
16. How To: Replace Install double Din Head Unit....................http://www.yourcobalt.com/forums/install-guides-diy/14800-how-install-head-unit-double-din-also.html
17. How To: Replace lower control arm (LCA).........................http://www.yourcobalt.com/forums/in...ow-replace-lower-control-arms.html#post613478
18. How To: Replace Headliner Material.................................http://www.yourcobalt.com/forums/install-guides-diy/31702-how-replace-headliner-material.html
19. How To: Test headlamps............................................. http://www.yourcobalt.com/forums/electrical/31219-how-test-headlamp.html
20. How To: TPMS Learn Procedure......................................http://www.yourcobalt.com/forums/install-guides-diy/21117-how-tpm-learn-procedure.html
21. How To: Wrap In Carbon Fiber.......................................http://www.yourcobalt.com/forums/install-guides-diy/8192-how-wrap-part-carbon-fiber.html.
