Levee
You can do one of 3 things. You can try to follow the trail of wet oil to where it is leaking, or, you can clean the engine with a pressure washer and drive for 15 minutes and look for the oil, or you can put a dye in the oil and drive it, then use a UV light and find the highest dye mark towards the front of the engine. This will tell you where your oil is leaking from.
