When i twist the knob to low beam on daylight it doesn't work but when the drl is engage the low beam is working. I don't know what is the problem. Can anyone help me thanks.
Discussion Starter #2
New update i found some on google and i tried it. My low beam only opens when i turn on the wipers. Is this a relay problem? Do i need to replace the whole fuse box to fix it?
Do you frequently use the light switch on the stalk? If so I'd go for the 2nd easiest thing to do (And most likely problem) and replace the turn signal stalk. Ive had 2 cobalts and both within a couple months of owning them needed their turn signal stalk replaced because the self cancel broke. I wouldn't be amazed if the light switch breaks to.
Correction. It cant be a relay or fuse if they turn on automatically. Id definitely go with replacing the stalk. You can get one for about $20 and theirs videos on YouTube how to do it. Should take about 5 mins
