Hey guys,
I was planning on putting black pieces over the lower grille valances I have, i dont have fog lights, there just straight across. I wanted some more information about them and how to install it. Do they just pop on top or do you have to basically cut out around where the original one is and then install the new one? any information is appreciated!
Yours are part of the front bumper. If you want the black inserts, you'll have to cut them (not recommended) to fit, or get an LT bumper with inserts (will have a hole for fogs behind the inserts).
You also could just tape off the grilles and paint/plastidip (the new craze sweeping the Cobalt Nation).
Okay thank you, that is what i figured is what would have to happen :/ sadly enough, i would feel more comfortable getting a different bumper instead of doing all that cutting. I appreciate the info thou.
you can get an aftermarket bumper relatively cheap. but then to have it painted would get expensive, but it would give you the best job
