1 - 13 of 13 Posts
ok so i have 215 45 17's on my cobalt i juss boout the eibachs pros.its says avg lowering is 1.4" ans 1.6" in the rear now is that gonna look good enough or should i take em back and get the sportlines pro but i am stayin on stock shock and struts . if neone has 17 and lowerd em. post pics . and also the sportlines said that the front were 2.o and 2.5 in the rear. so my question is is the rear gonna sit lower than the front cus if so ill stay with the pros....and if i do go with sportlines illb able to go over speed bumbs right and put my car on a lift that what im really worried abouT?
Back looks lower tho k one more ? Whos better eibach or h&r
---------- Post added at 04:15 PM ---------- Previous post was at 04:01 PM ----------
Cus the h and r recomend u replace shocks and struts wither ther loering kit for 2" and 1.6 in the rear but eibach doesnt
Get Out The Sawzall
All 2-2.5 kits will sit lower in the rear, everyone one of them!!! no matter what anyone tells you. Allot of guys cut one full coil out of the front lowering springs to correct this. However this does make the ride a little stiffer. You will be ok with the stock FE1 suspension, some guys have gone 100K on their stock shocks and struts. The FE5 SS shocks and struts are a definite improvement and will make one hell of a difference but they are not required.
Did u cut yours? I doont wanna cut mine thats kinds dumb cus why spend the money one springs juss to cut em ya kno. And what kinda of springs you got
---------- Post added at 04:50 PM ---------- Previous post was at 04:29 PM ----------
See i wanna be able to gove over like bumbs in the road with out me worring bout mties hittin my innner fenders or possibly cuttis my tires which if it does that you know its gonna bend the fender
my rear also has a shit load of weight in the back thanks to my subs, i didnt replace my shocks, but i will once they start to fail, but thats not going to be for a while
Ne got a pic with the eibach pros on??? With 17 or 18
Get Out The Sawzall
K-sports, yes I cut a coil, The spring rate is different when cutting a dropspring compared to a stock spring. No issues with rubbing, if I didn't have a driveway with a large hump at the top, I would cut another coil.
1 - 13 of 13 Posts
