1 - 20 of 41 Posts
i just got a 08 cobalt ls sedan. i want to get a cat back exhaust but don't have the money to do it right away. i was wondering if replacing the stock muffler with a magnaflow muffler would be worth the trouble in the mean time. would i get a performance gain? i also want a more performance type sound as well. any suggestions? thanx
depends.....a cat back isn't going to add a significant amount of power...it'll just sound like your going faster, especially in an n/a car. so unless you plan on boosting or building the engine go w/ the replacement.
in all actuality, the factory muffler is ungodly huge under the car. I apologize alpha_male1, but i have to disagree. The Magnaflow muffler is best for if you are hunting down a particular sound. I would not suggest a cat-back for an N/A car, just because of the cost of the system compared to the perks are not worth it. You might see a performance gain, but it will be so minute, that it wouldnt be reasonable. Only reason for changing the muffler would be the sound.(i think i actually agreed with alpha in the end, lol)
i think you need to read my post again....i said unless he plans on boosting or building the muffler is the way to go...in other words
muffler = sound catback = performance...on a built car anyway.
Discussion Starter · #6 ·
thanx for the responses. as lame as it sounds i wanted to change the muffler for mostly sound. i want performance too but i don't want to spend and arm and a leg for a cat back system. what size tubing does Chevy use? my engine is the 2.2L.
not sure on the stock size but it's small. however it fits the cars output.
2" system for all models EXCEPT the SC-TC(which are 2.25", i believe)
done systems on both 2.2l and 2.4l models
what a lot of people are doing are putting the stock ss s/c exhaust on when the s/c guys buy new exhausts...might wanna pick one up cheap if you can
agreed
On the 2.2's The exhaust gets as small as 1.8" towards the rear of the exhaust
see how restrictive it is .... Inch and a half...thats horrible
Here's a quick question...will the SS exhaust fit on a sedan? Are the cars the same length and what not? I am interested in doing that myself and found on on SS.Net, but not sure if it will fit the sedan. I don't want the sound of the aftermarket exhaust, but I want something a little less restrictive.
I dont see why not.....if it fits on the 2 door LS, it should fit on the 4 doors. same undercarriage
would the ss/sc exhaust on my 2.2L make it sound any different? i dont have the money or interest in performance as much as looks so i just want to know about sound...
it will give it a slightly deeper note, not too much, but noticeable
Okay noob time!! So, if i want to go the muffler route, 1) whats the best shape oval round... 2) Is there an offset I need to think about...3) Is there a model of magnaflow's that anyone reccomends for a low hum with just a little growl/ crackley (I hate to say) riceyness, or what I'm really looking for is like how an Infinity sounds.
1) Oval, it has enough volume space to give you a deeper sound(not like a hive of bees). 2) You want an offset/offset preferably, even a center/offset will work. 3)If you want a slight pitch change, go for the one step up model than the OEM replacement(dont get the performance model, it will be too loud).
1 - 20 of 41 Posts
