1 - 9 of 9 Posts
hey guys i just recently installed a spider cold air intake, and my check engine light came on stating mass air flow sensor or air volume low.
i cleared the code and 10 minuts later it poped back up again.
Is the reason its coming up with this code bc of the volume of the air is not the normal volume? the difference between stock intake and cold air intake?
Note: the cold air intake i intalled went down in my front bumper replacing my silencer.
You may have a leak or sensor may not be in far enough.
I noticed a difference on how she runs.
She will sure run differently if the MAF can't do its job, probably run rich.
---------- Post added at 10:55 AM ---------- Previous post was at 10:54 AM ----------
Do you have pictures of your install?
Also make sure you didn't flip airflow direction of "MAF"
1 - 9 of 9 Posts
