1 - 11 of 11 Posts
Hey guys, I come from the SRT4 world...just bought a 2010 Cobalt SS.
There were a bunch of mods you could do on the SRT4 but as we all analyzed the actual power gains overtime, everyone realized that if you were not big turbo with over 350 or 400 hp...some of them were a waste...
For example:
The intake on the SRT4 was actually very good and the gains achieved by switching it out were very minimal and in some cases detrimental....a drop in filter did as much or more than a CAI.
Big FMIC were also a waste unless you were big turbo..and running 350 or 400 HP +
and the suggestion was a direct fit although the stock intercooler was good it was prone to heat soak and the direct fit had thicker core etc. to combat the heat soak...but the Big FMIC had crappier flow, took longer to pressurize, so throttle response became compromised a bit...
So is there any popular but ineffective modifications for the Cobalt SS that everyone agrees that they are kind of a waste...if your not running big power.?
Thanks everyone...
Well I can't speak for the turbos, but from experience, building up your NA with bolt-ons is a waste if you want to make actual power. I put good money into my 2.2 to come out to an anemic 145whp.
So I bit the bullet and bought a supercharger kit. Somewhere between 230 and 240whp is right around where I hope to be once it's installed and tuned, which is pretty much the limit on our engines without built internals.
Levee
As far as the lnf, there really isn't anything that's a waste but a BOV with the stock turbo, and the cold side charge pipe. Other than that, everything else has been proven to give gains.
---------- Post added at 08:32 PM ---------- Previous post was at 08:29 PM ----------
Oh, and the stock turbos are limited to about 360ish whp.
Yep 360/420 ish WHP/TQ with E85.
A cat back is a waste with the stock turbo, hell a local was at 450 to the wheels and still running the stock exhaust. Over 400 though it can be beneficial to switch to a 3'' cat back.
Main things on this motor are intake (K&N is the go to) and a 3'' cat less down pipe.
Levee
You are able to get 360whp on 93, just some fyi. Byturbo and a handful of others did, but they were also running the pill mod.
Also as far as the stock exhaust, most don't realize it's 2 3/4 at the downpipe and 3 in cat back from the factory. Thus why exhaust upgrades aren't necessary.
Discussion Starter #6 (Edited)
I have been reading your Performance Q&A very informative!! Thanks for all the hard work you put into that!!
So initially you stated on the LNF engine that most mods are beneficial:
..........but now you stated that the exhaust upgrades aren't necessary...??
So is there anything else that you feel is not really necessary? Seems like in my SRT4, and other cars I have owned, the intake (although an easy install, fun to do and cleans up the engine bay a bit)....typically does not add anything.... Do you believe that the OEM intake on the Cobalt SS LNF is efficient and that a drop in air filter etc. is as good as a ram or cold air intake?
You still want a cat less DP just not a cat back.
Everyone seems to get an intake, but honestly I don't know how much it's needed. Makes it sound a hell of a lot better though so normally it's worth it to them for that alone.
I get what you were saying now...the cat back exhaust is already 3 inch but the down pipe can be improved due to a larger diameter and the removal of the cat. :thumbup:
How are you guys taking care of the cat- less codes? Are you tuning them out or using a defouler? I would think tuning them out would be obviously noticed by mother Chevy, but a defouler fools the system...at least it did on the SRT4.
Also, I know we got one exhaust tail pipe out the back....but has any aftermarket group come up with two tail exhaust and a rear bumper that accommodates two tails....this is of course completely a waste of money from a performance stand point but two tails looks so good!!
There was one company that used to make a dual exhaust they discontinued it. Only way now is to make a custom one like CAD did, same with the rear bumper you have to modify it yourself.
As far as I know they pretty much turn off the sensor when they tune the LNF, highly recommend a remote HP tune.
Levee
The exhaust is not a necessary upgrade on the stock turbo really. Getting a catless will free up torque and have better top end and quicker spool. I say it's not necessary because you can still max out the turbo with the stock exhaust. But it's a lot easier with a catless and you will have a bigger power band. Also, the actual muffler on the car, if you cut that off and just straight pipe it it frees up 5whp lol, and gives a good sound
Now as far as the code, you tune it out, defoukers are hit or miss on these cars.
IMHO, the best bang for the buck on the TC: HPTuners.
Stock 60-100 Run
My last TC's bone stock 60-100MPH run documented above: 8.76 seconds.
(If you're really bored with life, read this thread: LNF Ethanol experiment)
With ZERO mechanical modifications, E47% and HPT: 5.3 seconds. And I know some other mechanically stock cars went faster with better self-tuners behind the laptop :) not to mention back when I had the last TC HPT was quite crippled vs. now on the LNF. Think mid and lower 4 second runs.
60-100 Times :: TorqueStats.com
For $500 shipped, I just don't think you can beat it with a stick. Look at that link above, and you're talking about 60-100's that meet or exceed cars way above the Cobalts stature and original price.
1 - 11 of 11 Posts
