need some input i heard the 2.2 bottom end stronger then the 2.o and 2.4 if so can a 2.2 bottom end go with a 2.0 top end and what would i need to make it happen also would it be worth it as far as power
yeah the 2.2 is the weakest motor, if you turbo it you only get around 8-10 psi boost, and you get much more with the 2.4 and 2.0 motors
The rods are the weak point in the 2.2 and are rated to about 250HP - while the crank is rated to 600HP.
The 2.0s are stronger.
it thought the guy was full of crap just wanted to check to see if he was right now what top and bottom end are the strongest in the cobalt
