So I had a stage 3 racing clutch put in along with a new battery, and a new starter it ran good for a week with no problems then it didnt start again without assistance i even checked the neutral safety switch now I have a service airbag light. what else can it be cause I am at a loss for ideas. Can the service airbag prevent my ss from starting
Double check your work. the usual suspect to not startign after a trans swap or clutch job is the wiring. check you engine harness for loose or disconnected grounds.
