1 - 18 of 18 Posts
first off, idk if this is the right section to post this, but here it goes. so i used to have 8k hids (no high beam) and they burnt out, so i got new 10k bulbs with high beams. i hooked everything up properly and what not, but now my head lights wont flash when i unlock the doors and when i push forward to turn on the high beams they turn off completely but when i pull back the high beams turn on. has anyone else had this problem or know how to fix it? sorry again if this is in the wrong section.
the high/low function might be a problem because the old basliks didnt have that also when flashing the lights not enough power might not be getting to the lights..... ummm with the high low flick the wireing might be backwards or again not getting enough power in a certain setting
also check to see if its the right kit..u may have a 9004 bulb instead of the 9007...its a simple wire switch u have to do in the harness (think its the blue one that has to be switched with the white..please note don't quote me on the colours I'm not near my car, but I had to do that to mine cuz they sent me 9004s instead of 9007s)
naw i have 9007s. i made sure i wired everything right, but for some reason they still dont work. im gonna try to disconnect the battery and try it again. maybe i just need a reset? idk, but this is somewhat of an annoyance you know. any other ideas?
did u check ur ground for the ballasts? use sandpaper and scrape the paint off where u have it grounded, sometimes u may not have it as grounded as u thought (happened to me before with my 2 amps I had)
didnt have a ground for them ?!?!? i mean my 8000ks worked before, but now nothing.
U never had to ground urs? I got mine grounded by my rad support, my ballasts are hidden on my bumper frame
nope. my ballasts are hidden under the head light bracket.
don't know what to tell ya man..thought it might be the mix up in wires (9004/9007) or the ground, but if urs never came with one it can't be that...sure it never came with one? There's the positive wire that goes to the positive pole from the fusebox, and there should be another wire for ur ground....did urs come with a fuse attached to the positive wire?
Hey eyesore what kinda hids u got? Seems like they're ancient. Lol most hid kits are plug n play. Nothing to ground or wire to battery
Discussion Starter #11
nope these were plug and play bro
lol riiight
Discussion Starter #12
bump
I bought mine 2 years ago VVME bi-xenon 8000k....guess I was ahead of the game than u guys....
Discussion Starter #14
nothing wrong with that. i just need to figure out how to fix this!
Discussion Starter #16
have you checked the fuse ? maybe its blown or maybe you need a bigger fuse
Nope, but I'll look into that. Think I need a new one?
chould be you might need a bigger one im not sure but it sounds like the wiring is fine because its all plug and play and the other day my lights off while driving at night when i went to put the brights on and didn't realise so i thiought i blew a fuse and i did but i had noticed that it still worked when i pulled the thing twords me they came on so maybe it could be the fuse
do you have stock headlights?
Discussion Starter #18
Yeah they're stockers. I'm having the same problem as you.
1 - 18 of 18 Posts
