1 - 13 of 13 Posts
Was awesome.
So, I'll give a quick deal to a long story to see what you guys think of how this panned out.
Little background; car is a 2010 2LT, 44k~, Certified Used; all the factory warranties that are still there; are. Car has a K&N Drop-In, ZZP Hardpipe, and an Option Racing Catback. Nothing else has been touched other than me changing the oil and doing the coilovers/suspension parts.
Ok, so...Thursday Jan 31...had a CEL pop on. Went to have it read...car chucked like 32 DTC's leaning from heated o2 codes, to EVAP, to MAF, etc. Cleared them (btw car was idling like crap, MPG's weren't besting 20~ even cruising on the HWY). Called a buddy of mine who works at a local dealership who pointed me in the direction of a fuse titled "ENG VLV SOL"...and I really was "SOL". Pulled the fuse...it was blown. Simple fix, YAY! Swapped the fuse, car ran great...fast forward to Saturday, leaving work around noon (yeah, bankers hours...wheeee), funky idle kicks on again...CEL is back. Awesome. Go to the parts store, same situation. I think, ok, now I've got a wiring problem...it's popping fuses. I check the fuse...it's good...WTH?
As I put the fuse back, I realize that there is nothing holding it in.
That's right.
I get home with that awesome 18~ MPG's...rip apart the factory fuse box to find out that the terminals are no where to be found on the motherboard and pin F8A 17 and F88 were non-existent. Checked everywhere...found nothing. Junkyards had nothing as well (since the '06 Ion fuse box internals are different I got boned and wasted $17~ there as well). Turns out, no one locally sells anything like that...so, the soldering iron was whipped out and went to work. Removed the DRL pin from the top of the motherboard, soldered it in down on the F8A/F88 location...reverse angrily...and; car runs great.
Crappy part here is the dealership wanted NOTHING to do with the situation...basically quoted me for an entire wiring harness/fusebox swap.
Eff that, noise.
So...mean letter to GM I go :)
Damn, good thing you got it fixed
Fun times
pics or it didnt happen
---------- Post added at 02:52 PM ---------- Previous post was at 02:52 PM ----------
good to know youre back to running!
Like I stated...
F8A/17 and F88.
wow, its just gone lol thats nuts
The craziest part about the whole thing was that it's a pretty much sealed...everywhere.
No where for them to go.
Couldn't find them anywhere...pieces in the harness, bottom of the box that was still in the car, inside the case itself...just...gone.
According to my info your car is not suppose to have any fuse there anyway.
There was a 10AMP fuse there since I had bought the car.
It was also blown when the CEL popped on...replacing it fixed the issue.
Not sure if there is something underneath this causing the issue or what...but if it isn't supposed to be there according to your diagram you have, then why would it fix the issue would be my question to GM.
Coincidence maybe.
Discussion Starter #11
I see a few differences...
Where your 15 is above the bottom bolt, mine is a 20.
To the right of the bottom bolt, I've got a empty spot on the bottom, a 15 above that, then...with two 10's above it.
Everything else though checks out fine.
Somebody dropped his burnt fuse and it happend to fall in that empty slot. lol
Mine has no fuses or tabs in that spot. I can see one tab breaking away but 2 would be pushing it.
The fact that you took everything apart and put it back together could account for everything working well now.
Pull the fuse and see!!!
Discussion Starter #13
Trust me, I've been checking it everyday; paranoia factor has increased ten fold, LOL.
1 - 13 of 13 Posts
