1 - 16 of 16 Posts
My transmission likes to buck/shake/jerk (difficult to describe) in 3rd gear. It will only do this in 3rd gear, all of the other gears have no problems at all. It seems to just do it in lower rpms (between 1200-1800) and only if i am cruising at that speed and not just accelerating through that gear.
Anyone else ever had this problem??
Chevy Customer Service
Hello xfe,
I am sorry to hear you are having this shaking concern with your transmission. If you would like for us to work with your Chevrolet dealership on your behalf in regard to this concern, please send me a private message. Be sure to include your name, VIN, phone number, and dealership name.
Erica Tiffany
Chevrolet Customer Care
Took it to my dealership for this exact issue. They had 4 people drive it, and said nothing is wrong. Something is def. wrong. They dont want to fix it under warrenty.
Levee
Do the rpms jump around too or no?
It's a manual.
Levee
That doesn't make a difference to my question.
nope, RPMs stay the same the whole time. even at ~35mph in 5th if i put my foot to the floor on the gas the clutch wont slip.
Are you using the correct Dexron fluid? You know the trans fluid creates a "whipping" effect and can cause the jerk your describing. Have you taken a peep at your transmission mounts? I would try to eliminate the easy parts before digging through a transmission.
Levee
Any unusual sounds?
Car has 80k on her, and I will have to change fluid soon since it couldnt hurt. Transmission mounts should be fine, but when i get off work i will check them just in case. No unusual noises though.
What fluid will i need for the transmission?
Levee
Does it do it if you're cruising in 2nd at the same rpms?
Discussion Starter #13
It does not do it in 2nd around the same rpms, but i will make sure to test it tonight to see if i can get it to do it in 2nd or any of the other gears.
and alright, atf it is. ill have to go pick some up this weekend and get it done while my buddy has an open lift.
Wait a second 3rd at that low of RPM's is like 18 MPH, why are you in 3rd?
Where are you even going that slow?
Discussion Starter #16
Haha yup, its about 20mph. But not by choice, my job and girlfriend are both in columbus so i get stuck with the traffic and low speed limits (plus ~2100 rpms in 2nd on a stock exhaust doesnt sound good cruising). I check trans mounts and they seemed solid enogh to me. Might just need a fluid change.
1 - 16 of 16 Posts
