i just purchased an armrest for my ls and my interior is gray so i got a gray one except my dash and center console are black so i want to paint the armrest possibly. the plastic is the same as the center console and door is there a way to paint them? or am i stuck with a gray body of the armrest
thanks gooty
You should be able to paint it but only thing I could see that would present a problem is getting the right color to match with out it being tooooo noticeable.
you can paint it, but if you're gonna do it you might as well figure out your scheme and paint the rest of your pieces at the same time, usually when you paint the interior you end up with a smooth look instead of the grit look that the plastic has. thats just from what i've seen tho
Honestly i wouldn't recommend painting it.. Paint on something that takes as much abuse as an arm rest won't last long..
Discussion Starter · #5 ·
i put it in and it dont look that bad so ill jus keep it thanks for the input fellas
