i have a sony 12oo w amp. i would like to know how to hook the rca cables up to the amp. im keeping the stock head unit and dont know were to go from her. it came with the pioineer system so i dont know if there is an amp in it already or not.
What are you using the amp for? Is it a mono amp for a sub or multi-channel for speakers?
you can start by getting a speakerwire to rca line out converter.this will go on your rear speakers. next you will need a power source from batt. Then a remote wire,use something that has power when key is on only.ground the amp you should be good to go.
^That's what I did.
