i wanna take off the sealant on my headlight. I Kno i have to heat up the headlight so the sealant can unstick easier but wats the best way to take off the sealant?? as in to take off as much as i can to use hot glue or new sealnt
I used goo gone or you can use any adhesive remover and let it run in the channel and soak for a while. then use paper towels and a flat blade screw driver to scrape it out. I got mine almost perfectly clean and I have a perfect seal with zero problems on my headlights.
When I did mine I used a hair dryer to take it off the head light cover and. Left the glue stuff in and when I put it back together I just heated up that same glue and reuse it. And then added a little more on top to give it a good seal its been holding up so far
