Hey everyone, I need some advice here if possible. I have a 08 Cobalt with the 2.2 ecotec. About 8 months ago I started the cobalt and it would misfire for about 5-10 seconds then smooth out. It did this ever since then but only if it sat for hours (overnight etc). I suspected maybe a bad coil. Then after this, after it started and i would take off, i would hear a slushing sound. Then one day the car said cooling mode so I pulled over and let the car cool down, it was low on coolant so I added coolant and it was fine for about a month. It would still misfire at startup and make the slushing sound but wouldnt overheat. I would always keep my eye on the coolant and then one day it started getting hot again so i added more coolant and did this for about 2 months. I always kept my eye on the oil and now it is getting coolant in the oil. I figured it must be a bad head gasket so I ordered the gasket set. Ive been reading some how to's and came across a few threads saying that the water pump seal is a common issue for coolant getting in the oil. What would you guys say? Im just thinking its for sure the head gasket because of the misfiring which I think is coolant getting in the cylinders. Just dont want to put all this work into the head gasket and it not help. Thanks for any info
Take out your spark plugs and shine a light down the spark plug hole and see if there is coolant in the cylinders. If you do, then it's for sure a head gasket at the very least.
What color is your oil? Is it a peanut butter color? If so, then I would do the head gasket if there is oil/coolant in the cylinders, if not, then do the water pump.
thanks for the reply. There is cooalnt in the oil, it has the milky white sludge on oil cap & dipstick. Just looking for some extra advice. Does anyone know where I can get a step by step instructions? And will it have to be retimed or is there a way around it?
A milky white sludge doesn't always mean coolant. Could be regular heat condensation because of a PCV valve not working properly. That's why I was asking about the color of the oil.
When my son thought he had a bad head gasket he was losing power and white smoke out of the exhaust. It turned out he had a cracked block. But not until after her took the engine apart and replaced all the gaskets. A lesson learned but he was not happy.
if your motor was out of time, you wouldn't have a happy motor and you'd know it. you COULD be loosing coolant out of the water pump/pipe in the back, my car does a little bit. there is no way to replace the head gasket without re-timing your motor
