1 - 20 of 24 Posts
why is it red and why did you use that plastic hose?
ya. lol cool intake
Discussion Starter · #7 ·
i had a drop in kand n forgot to take off the sticker. also i used that red hose cause the elbow would not fit with hood closed and this is the best solution. works way better though
yeah that spectre one piece is to long to fit with a 90 degree on there. did you have to drill into the pipe for the MAF to fit?
Ehh... that hosing going to the TB looks horrible in my opinop.... but to each their own
Discussion Starter · #10 ·
yeah i drilled the hole for the maf sensor and it works great. no problems yet no codes.
Discussion Starter · #12 ·
yeah but it fit better that way less of a crunch ya know and thanks
Discussion Starter · #15 ·
nicebut i cant use the elbow on my car cause it wont fit right the hood hits before it can latch
Discussion Starter · #17 ·
iswear for some stupid reason it wont close with the elbow on but when i took off the elbow it closed.......it had to be hitting
Hey.... As long as it gets the job done... And did u make sure that the elbow was on the throttle body all the wya....cause if not then that is a possibility to cause it to rub
1 - 20 of 24 Posts
