Just put these bad boys in
And redid the armrests, in grey vynil
---------- Post added at 04:08 PM ---------- Previous post was at 04:07 PM ----------
Sounds so good now...
nice! you used the same mounting spot as me for your tweeters! IMO best spot! imaging is GREAT there.
looks good and bet it sounds good too :p
---------- Post added at 10:18 PM ---------- Previous post was at 10:16 PM ----------
how did you mount the tweeters? just drill holes through the door panels?
use a hole saw that matches the side of the tweeter. Drill it out. The tweeter comes with a little lip on the front that will pass over the hole slightly so you don't see the edges of the hole. On the back, there is a ring that screws on to the tweeter (at least for mine) that is slightly wider than the tweeter/hole so it holds it in place perfectly.
