Hey guys I just got a 2006 chevy cobalt from an auction at an impound yard was wrecked on driver side and the driver and back passenger doors are jammed but drives like a bat out of hell. What is puzzling me is yesterday it wouldn't crank so I got a jump and it cranked up on its own the whole day. Last night it wouldn't crank just clicked got a jump let it run a while turned it off tried to crank and nothing...so i'm thinking battery, but then someone points out that everything is working on the car and its charging my phone but won't start without a jump...what is wrong?
Check date code on battery and have it tested. Could be marginal. When it gets a jump and is running, it is getting charge and will have a higher voltage right when you shut the car off, and will probably work okay if started every couple hours. If you have a slight drain, the overnight drop might be enough to reduced the battery to where it cant crank over the engine.
Is there an aftermarket stereo installed with amp?
