1 - 20 of 21 Posts
Hey everyone, Im new to the site but, not to the cobalt world. I own a built LSJ, and ownd a heavily modded Lnf but, got rid of the LNF. Just wanted to start a thread and say hola. I have heard better things about this site than its cousin ss.net.
Thank you for the warm welcome.
Yeah I kinda figured it would happen sooner or later haha
just what i need, another ss that makes my car look bad...lol wlecome
Discussion Starter #16
I'll post pics later. What are the demands for pis?
welcome... to YC
Discussion Starter #19 (Edited)
well heres pics of my lsj(05) which i still have and my lnf(09) as well which i don't own anymore long story short (divorce) and some of the motor of LSJ. dont drool to much lol.
LNF MOD LIST
3” Race Down Pipe
Custom 3” Cold Air Intake
Custom 2.5” Hard Charge Pipes / 28x8x3.5 FMIC
Custom Tune
Custom Black Painted Rims
Custom Painted Interior Trims
Painted Black Headlight Housing
H.I.D. Kit, 10,000K
Led Tail Lights
Hardened Upper Motor Mount
Hardened Lower Trans Mounts
Lowering Springs
Led Front Turn Signals
Led Map Lights
Led License Plate light
LSJ MOD LIST
Exterior Modifications:
De-badged (All Badges Removed)
Custom Shorty Antenna
Switch Backs Led Corner Lights (White Running Light, Orange Blinker)
Skyline Style Led Tail Lights (Functional Inners)
Custom Front Upper Grill
Painted Silver Brake Calipers
Rims Painted Carbon Black
Painted Black Bow Tie
Carbon Fiber Outer Door Pillar
4th Generation Projector Head Lights
10K H.I.D. Conversion Kit (h7's For Projectors)
21 LED Fog Lights
Led Reverse Lights
Led Plate Light
Led 3rd Brake Light
Evo 10 Bumper Mod Carbon Black
Painted Supercharger/Intake Manifold And Whole Motor(Black W/Some Red Accents)
Black Gm Addiction Aluminum Caps (Coolant,Washer Fliud,Brake Resivor)
Dupli Color Rubber Under Coat (Complete Car Spraied With 1/8" Coat For Sound Deading,Prevent Rust)
Custom Plates (Lil Vett)
Interior Modifications:
Steering Wheel Buttons Custom Blue Leds
Steering Wheel Center Cap Painted To Match Steering Wheel (Flat Black)
SS/TC Seats (Swapped Out Of My SS/TC Before Sold)
Custom Painted Dash Inserts (Hammered Metal Finish Stock Color)
Blue Led Module Kit For Dash Cluster
Three Pod Pillar With (Autometer Cobalt Series 30psi Boost Gauge/Water Temp/Oil Pressure)
Custom Dual Cluster Pod (Aem Wideband/Volt Meter)
Avic-D3 In-dash Dvd/Nav
GM Performance Floor Mats
GM Center Console Arm Rest
80mil Dynamat (Complete Interior,Complete Trunk)
Flip Style Key Fob
Suspension/Drivetrain/Brakes:
Spec Light Weight Flywheel (7.5lbs)(With ARP Flywheel Bolts)
Spec Stage 3+ Clutch (Limits 596hp 610tqr)
Hurst Short Throw Shifter (33% Reduction In Throw)
Turbo Tech Racing Trans Mount Polyurethane Bushings In Stock Mounts (Custom Shims For Tight Perfect Fit)
Turbo Tech Racing Upper Billet Polyurethane Engine Mount
Custom Solid Driver Motor Mount (Packed With Polyurethane)
Intense Stage 2 Axles (Treated For Extended Strength After Bought)
Tenzo-R GT2 Lowering Springs (1.75" Front Drop 2.25" Rear Drop)(With Football Drag Bags)
OTTP Adjustable Koni Sport Shocks (Front Struts / Rear Shock)
Intense Polyurethane Control Arm Bushings (Custom Shims)
Custom 5mm Wheel Spacers
Moog Tie Rods (With Grease Fittings)
SFX Polyurethane Sway Bar Bushings
Bwoodyperformance Endlinks (3/4" Thick Over Stock 5/16")
ZZP Front Strut Bar (Powder Coated Black)
Turbo Tech Racing Rear Sway Bar (25.4mm (1")
OTTP FTP Stainless Braided Brake Lines
GM Performance Drilled & Slotted Rotors
Hawk HPS Pads
Rolled Fenders
NS-ll Performance Tires Drag Radials (225/45/18R) Slicks At the Track That I Own)
Performance Modifications:
Harrop 1320LSJ Sc No Current Dyno Numbers
Diamond Coated Forged Piston/Pin/Ring 10:5.1 (Full Point Above Stock) Also Oversized that of stock 86mm)
Custom Sleeved Block Sleeves Are Cryo'd and Thicker Than That Of Stock (Blue Printed Decked You Name it)
Built Bottom End
Custom Built Head Ported/Polished 7,200 Rev Limiter (7,600 When Playing)
Custom Balance Shafts Delete Kit (Deleted There Are No Balance Shafts At All)
ZZP Oil Cap Valve Cover Breather (From GTP Section)
Custom A/C Delete
Custom Cryo'd Oil Pump Gear
ARP Head Studs
ARP Main Studs (Custom Order)
Intense Cometic LSJ MLS Head Gasket
ZZP GM Stage 2 Belt
ZZP Adjustable Tensioner
Custom Ported & Polished Intake Manifold
Gates Performace T-Stat
AIS Big Trunk Mount Meth/Injection Kit (With Activation Led In Car)(Meth Comes On At 11lbs Of Boost 8gph 65/35 Meth Mix) (51/49 Meth Mix For Special Days)
Smoothflowpulleys 2.7 on Tvs
Custom 3" Intake (With 3' K&N Filter #F030C4)
LS4 Throttle Body (87mm)
Weight Reduction (Cars Factory Weight Was 2,975lbs, Cars Weight Currently 2,705lbs With Full Tank Of Gas)
Custom 3" Under Axle Exhaust System (Yes Under Axel I Have No Clearance Issues)(One Of A Kind Made 6/17/05) W/Magnaflow Muffler)
JBP Vortext Header Long Tube Shorty Header(Collector Internally Modified)
OTTP Second Gen Heat Exchanger (Aeroquip Hose & Fittings)
Meziere's Wp136S Aftercooler Pump (1200GPH) (Pump Custom Mounted With Special Aeroquip 12AN- Fittings)
Custom Dual Pass Endplate (With Aeroquip AN-Fittings)
HKS Oil Catch Can
Custom Oil Cooler System With Front Mount (-10an Braided Steel Lines, Car Now Uses 8.5qt Of Oil)
CED Fuel Filter
Custom Modified Fuel Sending Unit And Sock (In Tank)
ZZP 80LB Injectors W/Harness (E-85)
ZZP NGK BKR7E Spark Plugs (gap @.27)
ZZP Fuel Pump Re-wire Kit (Up Voltage To Fuel Pump)
OTTP Fuel Rail Fitting With Fuel Pressure Regulator
Custom Tune Hp/Tuners ( powered on m62 whp 326 wtq 290 On Pump Gas) Race Gas #’s I will not disclose those #'s to the public, Ran 12.235 @119mph @ track on 99 Octane race gas will be shooting for high 11s soon
Extras:
Wisconsin's First Built LSJ
Winner of Car Of The Month For January 2010
Given A Metal Of Excellence By Bill Ducan Of GMPerformance
Was In May/June Issue Of Domestic Driver Magizine.
LNF
LSJ
LSJ Motor
LSJ Motor
LNF Motor
1 - 20 of 21 Posts
