1 - 8 of 8 Posts
Coming home from work the other night, my 2006 sounded a bit rough starting up. I went into drive, and the car would not go over 30 mph. Tac also wouldn't go over 3k. Stopped at a traffic light and the car sputtered like it was going to stall. I pulled into a gas station, turned it off and restarted. Again a rough start and car wouldn't go past 30 mph. Let it sit overnight, now it won't start. It's not clicking like its the starter. Put an OBD2 on it, and it passed, no codes returned, but the check engine light is on. Any help would be appreciated. Car has under 65K on it. Mostly in town driving (5 miles back and forth to work mostly).
Almost sounds like the timing chain jumped a cog but hard to believe this would happen at such a low mileage. Does it have original idler or the revised version?
I believe it would be the original. I haven't had much work done on it, besides general maintenance. I did have an O2 sensor replaced over the summer and all of the recalls were done on it.
I would think both the car being clogged and jumping time would throw codes. The starter not clicking wouldn't be related the drivability issues, unless your issue is electrical. Wish I cold help more but without any codes, I'm afraid we are just guessing, but one good guess could fix the issue. Since there are no codes, it wouldn't hurt to disconnect the battery for a while and reconnect and try again. Also check the fuses. Another thing that can be checked is the connectors to the ECU and BCM take them the check for corrosion, that could always cause electrical gremlins.
Wait now just saw it's an 06, these are very prone to ignition module failures. It would explain rough idle and no power. If running on just two cylinders. May have dumped a bunch of fuel in the cat.
The thing that throws me off is the lack of codes. If the ignition module was shot he should be getting misfire codes (P0301-P0304) As well as getting the reduced power notification on the DIC. I just find it odd to have all those issues with no codes. I mean anything is possible, or maybe they just are not using the scanner properly.
?... It's not clicking like its the starter.....but the check engine light is on. ....Car has under 65K on it.....
Must ask......does the engine turn over but not start now or the engine will not even turn over??
Trying to eliminate old/ weak battery...
With the engine NOT running, check engine light does not tell enough.
So how old is the fuel and how full is the tank? (65k miles on a 10-11yr old car)
1 - 8 of 8 Posts
