Okay, so I just purchased an 06 cobalt. The car was not running when I got it. However, a little troubleshooting and I can get the car to start for a second or two when spraying it with starter fluid. Keep in mind I don't currently have a multimeter or test light. But I've noticed there is no fuel coming from the pump. Finally found a way to test power to the fuses and discovered there is no power going to the fuel pump fuse. The pump and relay are both new. The fuse is not blown or even burnt looking. (I've pulled the fuse.) Would anyone happen to know where I should look now?
Levee
Moved to correct forum.
