1 - 11 of 11 Posts
Administrator
Hey Guys,
This is a common issue with vb. The reason this happens is because there is a special character in your name. For example Bama-balt, you have a "-" in your name that would cause this. N.Y.C BOI, You have a "." in your name that would cause this.
In order to fix this we would need to remove the special characters from your name. The only one that works is a "_".
This happens randomly at any time. So sometimes your name will work then one day it will just stop working. This issues has also been linked with signature and avatar issues.
Sent me a pm with what you would like to change your username to and I will take care of it for you.
Thanks,
Dwayn
Rocket Power
Yeah, I remember this issue from other vB forums! IPB has a similar issue, also.
Im not sure if my message sent so incase it didnt, i have a problem with this too and would like a name change. "CobaltCDA" is the name i would like to change it to. i hope you get this, Thanks
edit-"This is to the administrator".
1 - 11 of 11 Posts
