Ok I have a 2007 Lt colbalt coupe. I salvage all of the wiring for doors and body harness (at least the wires that come from doors) along with switches, actuators, motors and even fuses from an ss and installed it into my lt however with all of the wires installed correctly to the connections none of it exept the power mirrors work my question is. Do I need to do somthing to the bcm programming like you would do when installing oem cruise control? I ask because if I connect the main power wires (green) to one of the battery wires the power windows work but not if I use the pins that I'm sposta; and I havnt figured a way to bypass the bcm for the power locks I dont care about keyless entry I just want the buttons to work.
Did you add all the wiring in the BCM connectors?
