1 - 12 of 12 Posts
I have a 2006 Cobalt and have a new oil leak on the bottom of the motor do you know what this could be
Sent from my KYOCERA-E6560 using Tapatalk
Probably coming from above, maybe the oil pressure sending unit's diaphragm has failed or a valve cover gasket.
I'm surprised your oil pan isn't leaking, it's got a nice ding.
Or is it AC Delco d 18498 for $11.38 on RockAuto and is this located on the front right above the starter
Is it where it's leaking from? And yes it's on the front above the starter.
There was oil dripping off the starter but I cleaned it all up and change the oil this morning I just drove it 5 miles and there's not oil near the starter only on the bottom in the picture so I don't think the pressure switch is leaking but I can't be sure
Best way is to shampoo the engine and clean as much as you can then take it out for a drive and check it. Did you change the oil before the picture or after?
The picture was after I changed the oil it's fresh oil leaking I'll try the shampoo this week and thanks
Possible if the rear main seal was leaking.
I had an oil leak in the same spot a few years ago on my 2006 Pontiac G5/Pursuit...Maybe I was lucky but a can of Bar's Leaks Rear Main Seal Repair and 2 oil changes later (using Motormaster 5w30 high mileage oil ), the leak was gone and hasn't come back !!!!! Good luck.
Discussion Starter #12
Sounds like a good idea when Coby told me it might be a main bearing I thought Lucas Oil engine oil stop leak so I put in a quart and I'll see what happens
1 - 12 of 12 Posts
