i just had my oil changed on my car ... my oil was showing like 18% so i went and got an oil change... my car is now showing 15% not showing that it was filled... how do i fix that?
^^like above OR you can turn on the ignition switch (engine not running) and push the gas pedal to the quickly floor three times. Make sure to let up completely after pushing it to the floor. This works on 06 and 07 models...should work on 08s...let us know if it does.
yeah on break ill run out there and see..... thanks for the info and even that little trick!
Another way would be to turn the tgnition on(don't start), push the I & reset button at the same time, the dic will say somthing about oil life, push reset button, then it will say acknowledged.
