1 - 10 of 10 Posts
If you have a catless downpipe or even a highflow cat the odds are that that's the reason why you're throwing that code. A tune can fix that. You're o2 sensor that runs on your header may need to be replaced also.
Hp tuners have no support for the 2.2. You would need to go with trifecta. I would try replacing your o2 sensor first and see what happens seeing that your code is saying bank 1
I wouldn't replace the o2 sensor. They're $80. Ain't cheap. If u still have ur stock dp then I would try installing that and check to see if the code pops up. You will have to clear it tho
1 - 10 of 10 Posts
